RSM+bluff body
Old   February 28, 2006, 10:24
Default RSM+bluff body
anto
I'm simulating a flow around a bluff body with RSM model. The y plus decreases under 11 in the points in which the velocity is zero. The results show correlation with experimental data. Can this be considered acceptable? Thanks in advance! Anto
Old   February 28, 2006, 13:49
Default Re: RSM+bluff body
se
It's perfectly fine to have such a small fraction of elements where y+ becomes too small.
Old   March 1, 2006, 10:39
anto
thanks you! So do you think RSM works fine with separation? Kind regards Anto
Bluff body used for diffuser testing lemat1 Siemens 0 December 5, 2009 10:11
Bluff Body krithiga Siemens 4 November 7, 2006 16:45
BLUFF BODY+ RSM Anto FLUENT 2 August 3, 2005 06:09
UDF for lift force on a bluff body sawa FLUENT 2 April 11, 2005 04:06
triangular bluff body Pratap Main CFD Forum 0 April 5, 2004 03:23
