regarding steady state discrete phase calculations
Old   February 27, 2006, 11:34
Default regarding steady state discrete phase calculations
hajszan_gyula
My question would be the following. If I do steady state, coupled discrete phase modeling (as classified by the Fluent 6.0 manual), then how are the trajectories being calculated? I.e. in order to get a trajectory Fluent integrates wrt to time, right? That contradicts the term "steady state". In order words what's the phyisical meaning of steady state discrete phase modeling.
Thanks a lot. Any response is greatly appreciated.
Old   February 28, 2006, 02:32
Default Re: regarding steady state discrete phase calculat
kiran kumar
in lagrangian approach your interest is "what happen to the particle at particular time and where it is",where as in euler formulations your interest is "what is going on at particular location wrt time",if it is not changing it is steady state.But in lagrangian approach you have to go with particle.the location of particle is based on the time only.whether it steady or unsteady.
if you got any better answer please share with us
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Steady State 2 phase problem fivos FLUENT 0 April 27, 2009 17:34
uncoupled discrete phase calculations AMV FLUENT 0 December 3, 2003 08:21
