spicies in mixture
Old   February 26, 2006, 13:44
Default spicies in mixture
chem
hi averyone who read it. I`d like to make an mixture in "materials" panel but there is only fluid and solid to choose in "Material Type". On Fluentusers web I`ve seen that they can choose "mixture". Haw to do that? What to mark before to be able to have "mixture", "solid" and "fluid" in this place?
Old   February 26, 2006, 19:15
Default Re: spicies in mixture
A
define Multiphase and then active the model you wish to use
Old   February 27, 2006, 07:35
chem
Ok Thank you very much
Old   February 27, 2006, 15:30
A
Nice to know someone who knows how to say thank you, anyway my comment should be read as follows define-> models-> multiphase and then activate the pertinent mixture model. You are also advised to read Tutorial 18
Old   February 28, 2006, 02:28
chem
thank you one more time. I will check it. I`ve check last you sggestion (i did`t reed tut18. I will do it after this email) and first thing I see is a can`t see (can`t choose) any solid spicies under Materials/mixture/edit. There is only gas and fluid. I`d like to do a salt solution (NaCl+H2O) to be able to have salt cristals after water evaporation. I will ask my support engeener for help aboute it too. regards chem
mixture mass continuity eqn v.s. volumetric mixture continuity eqn kaifu ANSYS 0 June 9, 2011 09:42
mixture mass continuity v.s. volumetric mixture continuity in pressure equation kaifu OpenFOAM 0 June 9, 2011 09:14
Improvement to the update of T_ et al in hMixtureThermoC and hhuMixtureThermoC richpaj OpenFOAM Bugs 2 October 9, 2008 23:14
Variable composition mixture .vs. reacting mixture Ting Wen CFX 0 January 7, 2008 07:04
Burning a CH4-H2 Mixture Jonathan Lemay CFX 2 November 12, 2007 18:01
