digitizing an aerofoil/ meshing problems
Old   February 25, 2006, 11:19
Default digitizing an aerofoil/ meshing problems
Simon
Hello there, Iam currently investigating an aerofoil performance. The problem is that i have had to plot the aerofoil myself since it corresponds to no known aerofoil, since its about 30 cm in cord length its very hard to get sufficient accuracy to create a good mesh. having to use a varity of programs to import these data points into gambit then having to resize it means the aerofoil is not a smooth shape. Does anyone have any experience in dealing with such a problem as i need enough accuracy to ensure i can find the transient point and find where separation is occuring. Also any tips on meshing, since ive used a square mesh the flow after leaving the trailing edge means the flow is at roughly 45 deg crossing square elements, i know this isnt good enough. Would be very glad for any reply by someone who has experience in this. Thanks
Old   February 25, 2006, 12:34
Default Re: digitizing an aerofoil/ meshing problems
A
few weeks ago, someone asked a similar question, I remember that good samaritans recommended A free digitizing programme, search previous posts, good luck
Old   February 27, 2006, 12:18
Simon
ok thanks, programs good but not quite accurate enough, think it best i blow it up on photocopier and do it by hand!
Meshing problems using Gambit Vianney FLUENT 4 May 30, 2009 04:45
Meshing trailing edge of aerofoil CC FLUENT 1 December 10, 2008 04:49
Aerofoil meshing eugene Main CFD Forum 1 September 7, 2008 01:11
Problems in Meshing Cyclone Sal FLUENT 3 September 19, 2007 11:21
Problems meshing a pie-shape cross-section bar-suggestions or workarounds needed Ricky Wong FLUENT 1 May 11, 2000 18:35
