slug flow again
Old   February 25, 2006, 01:18
Default slug flow again
shu ming
i can't see the air flow when i animate it. so i wonder why. maybe i how you guys out there draw the column when using gambit?plus the gas inlet velocity,what is the magnitude?
Old   February 25, 2006, 13:33
Default Re: slug flow again
Leejun
Hello Shu ming,
Did you managed to get any results for your slug flow? I am also trying to simulate slug flow can you give some advice like whats your Boundary conditions and initial conditions.
Thanks inadvance for your kind help
Best Regards Cheong Yong Huat
two phase slug flow Justion FLUENT 4 June 5, 2014 11:47
Slug flow in a vertical pipe Abe FLUENT 0 March 29, 2007 10:01
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 09:42
Slug Flow Paul_C FLUENT 0 December 14, 2005 00:17
Slug flow in square channel PaulC FLUENT 0 December 5, 2005 03:03
