February 23, 2006, 14:06 |
XY Plotting with ANGLE - Possible ??
Hello ! I'm working on a supersonic body, with shock waves.
I've already plotted the pression (overpressure and depression) folowing the X axis, using fluent tutorial. But I would like to measure the pressure perpendicular to the shock wave (I already know the angle of the shock wave). Doea anybody knows how to do it ?? ( http://img151.imageshack.us/img151/5853/image14rz.jpg ) |
February 23, 2006, 14:59 |
Re: XY Plotting with ANGLE - Possible ??
You can create a line (Surface->Line) and use two points that could represent the line. The points you enter are the end points of the line, so you have to make sure that you're putting a point on both sides of the shock, and then you can do an xy plot, and use Curve Length instead of direction vector as your X Axis function (or you could put in a vector that points from your start point to your end point).
Hope this helps, and good luck, Jason |
February 23, 2006, 17:05 |
Thanks !!
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
Normal vector, slope and aspect angle | g_niro | Main CFD Forum | 0 | February 2, 2011 18:24 |
About velocity angle when plotting a contours | wateraction | FLUENT | 0 | July 25, 2010 00:24 |
Plotting particle wall impact angle (Lagrangian pt | Bart Prast | CFX | 0 | January 26, 2009 05:23 |
Plotting of lift coefficient vs angle of attack?? | John | Main CFD Forum | 1 | August 18, 2003 10:31 |
