Re Number
Old   February 23, 2006, 03:50
Default Re Number
mAx
Hi, I am a little beat confused with Re Number. I have an inlet pipe with a D diameter. This pipe is connected with a valve, in which moves a piston. Now my question. Should I evaluate my Re number with inlet pipe (eg. with D diameter), or should I take into account the piston opening? In the last case, Re number is fully dependant of piston opening, and describe much more the flow characteristics. Any Advice? Thanks a lot.
Old   February 23, 2006, 04:56
Default Re: Re Number
Ravi Kiran
Hi mAx
i feel that the concept of wetted area would be very much appicable for this case
for estimating the Re of an annulus we need to used piston in the pipe
i think mean hydraulic diameter should be used for estimation of Re in the above case
bye Ravi Kiran
Old   February 23, 2006, 05:39
mAx
Hi Ravi, Thanks four your reply. This is what I was thiking too.
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 13:55
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
