turbulent viscosity limited to ...???
Old   February 21, 2006, 14:56
Default turbulent viscosity limited to ...???
alexandre
I am trying to simulate an axisymmetric body with an unstructured mesh (3d,coupled imp, S-A). Fluent works with 1000 iterations and after 165 iterations, the text says : "turbulent viscosity limited to viscosity ratio of 1.e+05 in (n+1) cells" The simulation continues with this phrase for each iteration
Do you think that's modified the results of my simulation?
Thank you for your help...
Alexandre.
Old   February 21, 2006, 15:25
Default Re: turbulent viscosity limited to ...???
Jason
This has been discussed in detail on this forum. Basically comes down to Boundary conditions or mesh. In my experience it's usually the mesh. Do a search of the forum ("turbulent viscosity ratio" or "TVR") for more details.
Good luck, Jason
Old   February 22, 2006, 00:22
Ravi Kiran
One wAy to handle this problem is by refining the grid at boundaries by hanging node method in Flunet i.e. adaptive boundary gradients with respect to y+ and reduce the Y+ value to half after every 100 or 200 iterations
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 07:15
turbulent viscosity limited to viscosity ratio of 1.000000e+05 syler3321 FLUENT 4 March 16, 2012 17:00
Turbulent viscosity limited to viscosity... Cyril FLUENT 16 October 4, 2007 07:12
Turbulent viscosity limited to viscosity ratio... Cyril FLUENT 8 February 7, 2006 21:34
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 07:13
