boiling
Old   February 17, 2006, 03:45
Default boiling
Kaatje
Hello, I am simulating boiling of a fluid in a tube. Therefore I use the UDF that fluent prescribes in an example: m_lg = -0.1*C_VOF(cell,liq)*C_R(cell,liq)*fabs(C_T(cell,li q)-T_SAT)/T_SAT as the source term in the equations. Does someone know where this formula comes from, what the theoretical background is of this formula? Thanks, Kaatje
Old   February 17, 2006, 07:43
Default Re: boiling
Grzes
I don`t know where is it from but on www.fluentusers.com you can find at least 2 tutorials aboute boiling (surface boiling). Maby it will help you somewhy regards grzes
Old   February 17, 2006, 08:35
Default Re: boiling
Kaatje
I already tried out these 2 tutorials but they don't explain the UDF for the source terms. But thank you for your suggestion. Kaatje
Old   February 20, 2006, 02:57
Default Re: boiling
turbomachinery
Hi ,
the function is gotten by experience and lab analysis, you need experiment data about boiling rate then the coefficient of the function may be availiable. I also want to get Hydro oxygon boiling coefficient. if you know or you have any suggestion, please let me know!
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Stability problem due to turbulent dispersion force in a subcooled boiling model Edy OpenFOAM 7 August 10, 2011 13:00
Boiling on Mountaintop Frank Main CFD Forum 3 January 16, 2009 17:33
VOF vs BOILING greg FLUENT 0 April 1, 2007 11:59
pool boiling curve David Gibson Main CFD Forum 0 November 11, 1998 00:06
