Constant Heat Flux / Temperatures too high
Old   February 16, 2006, 14:14
Default Constant Heat Flux / Temperatures too high
Didio
Hi all,
I am trying to model the tempertare field in a ventilated space using Fluent and am having difficulty with one of the boundary conditions. I have a heated plate in the middle of my room. If a I specify a constant temperature bc I get a solution that works, but isn't what I'm concerned with. If I specify a constant flux (say 1000W for a 1kW heater) I all of a sudden egt temperaturesin my domain of 5000K, which is obviously ridiculous. Even when I reduce the heat flux to less than 40 W (less than a light bulb) I still get ridiculous answers.
Has anyone else encountered this and if so what can I do?
Diogo
Old   February 16, 2006, 14:49
Default Re: Constant Heat Flux / Temperatures too high
vivek
What are the boundary conditions you apply to the wall of the room. If u say all the walls are adiabatic, then the heat added by the hot plate just stays inside the room and the temperature keeps on increasing until infinity. Try to define a zone where you can apply a mass flow boundary or a constant pressure boundary.This will take care of the heat being carried away by advection.
Old   February 16, 2006, 21:57
Didio
No that's not the problem - I have a flow in at low level and out at a high level, which as you said i sprecisely supposed to carry the heat away, but it doesn't do that and temperature doesn't climb to infinity, but some unrealistically high level.
Thanks for the suggestion though
Old   February 17, 2006, 13:07
Evan Rosenbaum
Have you compared the heat flux you are trying to apply with the FLUENT-computed heat flux when you apply the constant temperature condition? This might help steer you toward the source of the problem.
Total heat transf. rate vs Total surface heat flux Renato Sousa FLUENT 1 April 14, 2020 04:27
How to set a initial temperature and constant heat flux at same BC's?? Jane FLUENT 4 October 25, 2015 13:01
Heat flux in ansys cfx juliom OpenFOAM Running, Solving & CFD 2 April 14, 2009 15:30
constant heat flux BC sunny Main CFD Forum 3 January 21, 2005 11:03
BC for constant heat flux saidi Main CFD Forum 2 July 17, 1998 16:02
