convergence problem with FLUENT cavitation model
Old   February 16, 2006, 10:01
Default convergence problem with FLUENT cavitation model
Belete Kiflie
Dear all,
I am using the full cavitation model implemented in FLUENT to do simulation of cavitation problems in an axial pump. I had generated a mesh of 1.1 millions. I used this mesh to simulate the flow with fluent using all the three k-e turbulence models (standard, realizable and rng). The calculation converged well and the solution appeared good. Then, I wanted to start solving the cavitation problem. But this time, it appears that the convergence stuck...but it appears the solution is not bad...to improve the convergence, i tried to lower the URF for vf but the residue jumps to a lower value at the biginning but then it stucks immediately after....can you help?
With best regards
Old   February 18, 2006, 03:04
Default Re: convergence problem with FLUENT cavitation mod
R.Arazgaldy
Dear B.kiflie I would like to simulate cavitation on marine propeller. But i in confuse that if it(Fluent) can do it?
can you help me?
Best regards R.Arazgaldy
Old   February 18, 2006, 06:53
B. Kiflie
Hi R. Arazgaldy,
I am also trying to use FLUENT for solving cavitation problem on an axial pump...the cav. model implemented in FLUENT is one of the most accepted model. It is called FULL Cavitation Model...it has been also reported in different papers about its applicability...that was I was encouraged to start using it...but for the time being i have some problem regarding convergence issues as I posted it earlier to which I am looking for advice...but the initial results i got are promissing...
Old   February 20, 2006, 11:16
Davy
Hi,B. Kiflie
I'm also using fluent to simulate cavitating flow in axial pump.Would you please send me some of your good results? And I don't clear where and how to set the operate pressure.
Integration of a Custom C++ Model into FLUENT Syed Haider FLUENT 2 March 7, 2018 00:37
problem with UDF for (v2-f) turbulence model in fluent artemiss1984 Fluent UDF and Scheme Programming 6 January 17, 2014 06:50
How can FLUENT be used to model a transient problem with changing geometry? Fascal FLUENT 0 June 30, 2010 16:21
Submerged fin, Convergence problem supermouniette FLUENT 10 July 6, 2009 11:47
FLUENT cavitation model CFDtoy FLUENT 4 October 15, 2008 11:31
