February 15, 2006, 16:45 |
specific heat
hi I need to make a new material in Fluent. I need to do a solution of salt and water. It`s properties depand of temperature and concetration. How do do density, viscosity I know but what aboute specific heat? Is it possible or not. In my case specific heat change its value with temperature and concetration changes. Haw to deal with this problem???
February 15, 2006, 22:18 |
Re: specific heat
Hey Man, I think you have to use UDF function. You can see many example about DEFINE_PROPERTY macros in UDF manual. If you don't have this manual please say me. Best Regards, Farid,
February 16, 2006, 12:18 |
Re: specific heat
Yes you are right that we can define all properties by UDF. All bur not a specific heat. Bellow is an part of UDF Tutorial:
{".......UDFs cannot be used to de ne speci c heat properties; speci c heat data can be accessed only and not modi ed in FLUENT........" 4.3 Model-Dependent DEFINE Macros} So haw to deal with it? regards |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
