February 15, 2006, 14:34 |
laminar simulation
Hi to all
I have a question: it's mistaken to carry out a laminar simulation with a value of Reynolds number of about 2000000? Thanks |
February 15, 2006, 21:19 |
Re: laminar simulation
Hey Man: What's your problem. May be in flat plate yuo can do it but in pipe you can't. Because your problem become turbulent. Best Regards, Farid,
February 15, 2006, 21:25 |
It depends on your problem. For example, if it is pipe flow (with a sharp-edged entrance), the laminar-turbulent transition takes place at approx. Re(-based on diameter of pipe) of 2300(Lower limit), and for a flat plate, Re(-based on distance from the leading edge) is around 3.2x10^5(lower limit)for transition.
Regards, Rajesh |
February 20, 2006, 07:37 |
If your problem regards the flow on a cylinder you can find useful to read this tutorial:
http://www.fluent.com/software/stude...l_cylinder.htm However if your flow has a Re of around 2000000 you have to use a turbulent approach. Regards Emanuele |
Laminar flow and wall roughness | junbbung | FLUENT | 2 | November 26, 2022 21:22 |
Replacing mesh while running a simulation | akultane | CFX | 1 | November 15, 2009 13:46 |
How to determinate turbulence scale in LES (laminar simulation)? | Franciswu21 | ANSYS | 0 | October 22, 2009 12:48 |
Laminar field as initial state for turbulent two phase pipe flow | kjetil | OpenFOAM Running, Solving & CFD | 3 | July 21, 2009 09:15 |
urgent: 2d laminar boundary layer simulation | Abhishek | Main CFD Forum | 2 | August 1, 2006 19:17 |
