Error meshing volume (Gambit)
Old   February 14, 2006, 13:09
Default Error meshing volume (Gambit)
Eduardo
I´m trying to mesh a volume in Gambit but i keep getting this message of error:
Error: Assertion failed in RefVolume.cc, line 6059: found_1 && found_2 while meshing v_volume.1.
Does anyone have an idea of what this means or how can I correct this error?
Thanks a lot
Old   February 15, 2006, 05:04
Default Re: Error meshing volume (Gambit)
MANOJKUMAR
I think there is a lagre volume in which a small volume so this type of messgae occur. Please give detailed about ur geometry
Old   February 15, 2006, 11:57
Eduardo
My geometry consists of faces that delimit a car model and faces that create a cube around it. The car is glued to one side of the cube, so if you look from outside you can see the mold of the car.
The volume was created by the car and cube faces. I meshed the car faces, but when I try to mesh the volume the error comes:
I would appreciate if you could help me.
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
Split Volume in Gambit Meenu FLUENT 5 May 2, 2011 23:26
Meshing Volume in Gambit for a water turbine Zaqie FLUENT 1 July 24, 2009 02:25
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
