help with DPM particle position
Old   February 14, 2006, 12:56
Default help with DPM particle position
Josh
When I want to get the particle position in cell and thread,
c=P_CELL(p); t=P_CELL_THREAD(p);
the following error occurs: ------------------------------------------------------ implicitly declaring function to return int: RP_CELL(). ------------------------------------------------------
Thanks a lot!
Old   February 14, 2006, 15:11
Default Re: help with DPM particle position
Allan Walsh
Have you included the function RP_CELL in your code before you try to access cell position. There is an example in one of the DPM macro examples in the UDF guide that shows it, without much explanation. (I'm not at my office right now so I can't look it up) - but you should be able to find it.
I have used this for finding the particle position in my code and remember having to include the RP_CELL and I think one other macro.
Old   February 16, 2006, 13:10
Josh
Thank you very much! I solved my problem even without using RP_CELL, but now I know its usage. My another question is, how to get the particle number and diameter in a cell when particle sizes are different?
Best Regards,
Josh
DPM particle time step amos FLUENT 1 January 4, 2020 09:46
print position of Lagrangian particle? sven82 OpenFOAM Running, Solving & CFD 4 June 16, 2016 09:58
DPM UDF particle position Tom FLUENT 8 July 25, 2015 13:30
Force dependent on particle position jranita OpenFOAM Programming & Development 1 August 23, 2011 20:44
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
