compiled UDF
Old   February 14, 2006, 11:43
Default compiled UDF
erica
Hello!I have a problem in fluent.When i try to compiled more then one udf file, when i do build,fluent shows this message: "Error Object: ()
1 file(s) copied.
1 file(s) copied.
1 file(s) copied. (system "move user_nt.udf libudf\ntx86\2d")0 (system "copy \software\Aplicacoes\FLUENT6.1.18\fluent6.1\src\ma kefile_nt.udf libudf\ntx86\2d\makefile") 1 file(s) copied. 0 (chdir "libudf")() (chdir "ntx86\2d")() 'nmake' is not recognized as an internal or external command, operable program or batch file. 'nmake' is not recognized as an internal or external command, operable program or batch file. Done."
And then,when i do load,shows this one:
"Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified." Can anyone help me please? thank you
Old   February 14, 2006, 12:05
Default Re: compiled UDF
Josh
Hi, this seems a general problem. mAx just sent me instructions about this and I haven't done it. But you can try it. Tell me if you solve the problem.
Josh
http://www.cfd-online.com/Forum/fluent.cgi?read=35972
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
I want to use pressure of 1 face in udf that compiled on other face iman_1844 Fluent UDF and Scheme Programming 3 June 10, 2010 13:55
Why udf can not be compiled in my pc? Xinqiang FLUENT 0 June 10, 2009 15:32
difference between udf compiled and udf interprete chandra sekhar FLUENT 2 April 11, 2006 01:04
how to quit compiled or interprited UDF tian FLUENT 0 April 9, 2003 00:53
