parse error
Old   February 14, 2006, 07:48
Default parse error
Tajul
Hi everyone I'm trying to pass the Interpreted UDF to Fluent 6.1. But the program generates the following messgae: line 1 parse error. When I use compiled it is ok. My UDF is correct. Can anybody help me?
Old   February 15, 2006, 00:51
Default Re: parse error
shanu
pls fwd ur sourse code to shanuraj82@yahoo.com
Old   February 15, 2006, 02:49
Default Re: parse error !!!!!!!!!!!!!!
Ahmed
What you need is a good C language primer and an English dictionary. Why The parser is a programme that reads a text file and translates its contents to the equivalent machine language. If you have parse error is because you are not following the syntax of the C language (in this case)
Old   February 16, 2006, 10:46
Makaveli
This will occur running fluent in windows if the udf file is a directory which has spaces in the path e.g C:\My Documents
Try moving the file to something like C:\temp
Old   February 16, 2006, 23:58
Tajul
Hi Makaveli Thanks a lot. My problem is solved by you suggestion. I appreciate your help. Thanks again. Bye regards Tajul
Old   February 17, 2006, 05:24
Makaveli
Not a problem. From what I can understand this is quite a common error and no where in the documentation does it tell you how to avoid it.
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
nonNewtonian viscosity model mhassani OpenFOAM Programming & Development 5 January 7, 2013 10:27
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 21:23
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 21:11
user defined function cfduser CFX 0 April 29, 2006 11:58
