February 13, 2006, 04:18 |
User sclar boundary condition.
Hi!Does anyone know wall boundary conditon for a UDS,thi, as:
d/dn(thi)=0 and d/dn(thi)=S; According to the mannual you can only set: 1)thi=fixed value and 2)flux of scalar = fixed value Since I can access grandiant of scalar through C_UDSI_G(c,t,i)[x] where x= 0,1,2; but how should I set the gradiant of scalar as fixed value S? or should I have to solve two scalar equations and couple them? Does anyone know how to deal with this problem? |
February 13, 2006, 11:15 |
Re: User sclar boundary condition.
the flux of the scalar is d(Phi)/dn
February 14, 2006, 05:14 |
yeah, thank you for correcting !
February 15, 2006, 03:56 |
the UDS equation I am going to solve is a laplace equation.
the scalar thi represents Electric potential. and convective flux is not to be computed and the equation as the UDF mannual is: -d[(diff*(d(thi)/dxi)]/dxi=S ; and at one wall ,I have to define the gradiant of scalar as a specified value,and how shall I resolve it? any suggestions or comments would be welcomed! Thanks in advance! |
February 15, 2006, 12:32 |
As i said in my previous reply, you just set d(Phi)/dn at the boundary.
For scalar equations, the boundary conditions are either specified value, specified flux, or mixed. It is confusing when u say "gradient of scalar as a specified value". In any case, you can either specify the value of Phi or the flux of Phi at the given boundary. When you open the boundary conditions setting in Fluent, you will have the option to do that. Hope that helps. |
February 16, 2006, 02:41 |
thank you ,Ynot!I see now!
February 16, 2006, 03:47 |
The flux is not simply a gradient,
The flux is always defined as FLUX =-Diff*d(phi)/dn Be carefull : n is the direction normal to your boundary and directed INTO the flow. Do not forget the sign (-)... Do you have a constant flux, or is it a function of something else ? Are you modeling some MHD flow? |
February 17, 2006, 01:00 |
thank you,Kharicha !
the flux should be : FLUX =-Diff*d(phi)/dn ; the flux is not constant ,but a function of the internal conditions of the fluid zone; by the way,what is MHD mean? |
February 17, 2006, 02:06 |
#9 |
Magnetohydrodynamic=MHD!
So I wonder what is the purpose of your study if it is not MHD ? |
February 17, 2006, 07:03 |
#10 |
Can you tell me what scalar you are defining with UDS.
February 19, 2006, 23:01 |
#11 |
not MHD,but fuel cell
February 22, 2006, 21:58 |
#12 |
Electronic potential,I've mentioned.
Mixed/Robin boundary condition | aaev | OpenFOAM Bugs | 2 | December 15, 2011 15:03 |
How exactly the "pressure outlet" bdry condition compute properties on the boundary? | yating9901 | FLUENT | 3 | June 28, 2010 13:26 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 07:18 |
