Heat Transfer on the outer surface of cylinder?
Old   February 11, 2006, 21:04
Default Heat Transfer on the outer surface of cylinder?
Alireza
I was just wondering if anybody has done a project on calculating the convection heat transfer coefficient on the outer surface of the warm cylinder placed inside the wind tunnel to cool down. Thanks Alireza
Old   February 13, 2006, 02:18
Default Re: Heat Transfer on the outer surface of cylinder
Alireza
sjhajh
Old   February 13, 2006, 03:22
Ralf Schmidt
that's not a simple simulation...
the calculated heat transfer depends on the turbulence, the turbulence model (k-omega is said to give the best results), the mesh (Boundary Layer) y+, wall treatment (wall function), temperature dependency of the gas values at the temperature close to the cylinder,....
I am on the same simulation, but so far... not very succsessfull.
Beside this, a correct measurement of the heat transfer on the cylinder surface is difficult.
best wishes! Ralf
Heat Transfer from a Rough Cylinder in Tunnel RE=2.2E5 M=0.07 aerothermal OpenFOAM Running, Solving & CFD 9 May 23, 2013 05:12
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
surface to surface radiation heat transfer? suresh Siemens 1 July 7, 2006 07:54
Question on heat transfer coefficient!!! Benny FLUENT 7 June 7, 2005 10:25
