compiled udf error
Old   February 10, 2006, 16:22
Default compiled udf error
mehrdad
Hi to all fluent users; I installed visual c++ 2005 for runing compiled udf programs, but when i run steps according to udf manuals fluet issue this messages:
1- when clike build, issue message is:
1 file(s) copied. (system "move user_nt.udf libudf\ntx86\2d")0 (system "copy D:\fluent.inc\fluent6.1\src\makefile_nt.udf libudf\ntx86\2d\makefile") 1 file(s) copied. 0 (chdir "libudf")() (chdir "ntx86\2d")() Done.
2-and when I clike load, issue message is: Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
please help me thank you
Old   February 13, 2006, 16:08
Default Re: compiled udf error
Ravi Duggirala
After installing the compiler, some environment variables need to be set. The steps have been described in following link: http://www.fluentusers.com/support/i...udf_serial.htm
hope it will solve ur problem
ravi
Old   February 13, 2006, 16:25
Ravi Duggirala
http://www.cfd-online.com/Forum/fluent.cgi?read=35957
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 06:48
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
