quasi steady analysis of 2d airfoil (pitching)
Old   February 9, 2006, 22:33
Default quasi steady analysis of 2d airfoil (pitching)
Alex
I'm trying to do a subsonic analysis of an airfoil undergoing pitching motion using Fluent. Could anyone tell me how to get started or where to find help? It is part of the analysis on a flapping insect wing. At this point I want to simplify the problem as much as possible.
Do I need to learn how to create a dynamic mesh in order to solve this problem.
Eventually I'd like to perform unsteady analysis (pitch and plunge).
Help is greatly appreciated.
Thanks
Old   February 10, 2006, 03:54
Default Re: quasi steady analysis of 2d airfoil (pitching)
Seyed Farid Hosseinizadeh
Hey man, You need to read the Fluent Toutorial Manual. Please see the contents. The first good example is in section 3-1 "Modelling external compressible flow" that exactly related to Airfoil. After that I encourage you to read the example in section 4-1 that is "Modelling unsteady compressible flow" that you will learn a lot about unsteady form of solution. At the end to learn the Dynamic mesh please read the section 11-1, " Using Dynamic Meshes". If you want anything please contact me.(hossesf@auburn.edu) Have a good night, Farid,
Multi-element airfoil analysis CFD Rookie Main CFD Forum 12 November 17, 2016 07:07
Steady level flight airfoil analysis using ANSYS CFX v12 flutter CFX 21 March 29, 2016 04:51
airfoil analysis need help!!! DLC OpenFOAM 4 April 9, 2010 10:24
Airfoil Mesh for DES Analysis - y+ Value asd Main CFD Forum 1 May 3, 2007 11:13
y+ for Airfoil Analysis asd Main CFD Forum 3 April 18, 2007 11:54
