February 7, 2006, 18:39 |
Printing Values on a Specific Surface
I wish to obtain a list of pressure values on a particular wall surface. So far i am only able to obtain an XY plot of pressure against X coordinate, for the particular wall surface i am interested in. Instead of a graph i would like a print out of actual pressure values with their corresponding coordinates (ie the numeric data used to construct the XY plot). The reason i wish to obtain these values is to ultimately determine the location of the centre of pressure. The object i am dealing with is essentially a stationary 2D square in a flow of air. Using the pressure values, i will use Excel to numerically integrate to ultimately determine the centre of pressure. Is there a simpler way to do this within FLUENT? For example using surface integrals etc. All help appreciated, Matthew |
February 8, 2006, 09:15 |
Re: Printing Values on a Specific Surface
Export and ascii file (File->Export, Choose ASCII under File Type, pick the surfaces under Surfaces, and pick Static Pressure and the coordinates under Functions to write).
Hope this helps, and good luck, Jason |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 12:05 |
Acessing neighbouring values in specific directions | RoE | OpenFOAM | 10 | October 4, 2012 04:38 |
printing values from udf!!! | Shekhar | FLUENT | 2 | January 13, 2004 12:49 |
