Fluent - Windows XP-Prof 32bit - 4 GB RAM
Old   February 7, 2006, 04:45
Default Fluent - Windows XP-Prof 32bit - 4 GB RAM
Peter Specht
Hallo,
you can manipulate XP (32bit) to allocate 3 GB-RAM/task. 1 GB is then for XP. Who has experiences with Fluent/Gambit running such big models with a single processor? 1) Is it possible? - Or are there limitations by the c-compiler allocating more then 2 GB/task under Windows XP? 2) Is Fluent/Gambit running stable with such big tasks?
Regards Peter
Old   February 9, 2006, 05:13
Default Re: Fluent - Windows XP-Prof 32bit - 4 GB RAM
K.Jagus
I use Fluent on 4gb RAM Machine, but with two Xeon processors. I can say that the memory management is largely limited. From my experience Fluent would not run when allocated slightly more than 1.2 gb per process. I use 3 mln cell grid and have to enable hyper threading to simulate 4 processor machine to distribute RAM into smaller chunks. On 2 processors, Fluent gives me out of memory errors.
Old   February 10, 2006, 02:21
TomK
Hi there!
I use not Fluent but other software and faces same problem. I have 2 xeon and 4 gb ram, but limit for 1 cpun seems to be around 1.2 gb as already mentionend. I am running under win 2000 and think this problem is more related to ms windows?
Tom
Old   February 10, 2006, 12:12
clem
You should check if windows XP doesn't limit the memory allocation to Fluent. More info: http://www.microsoft.com/whdc/system...AE/PAEmem.mspx Best regards
Old   February 12, 2006, 10:36
Ahmed
Use LINUX OS Windows is good for office work and documents
Old   February 14, 2006, 13:05
Vinod Dhiman
Hi
We use Fluent with 5 Intel-IV processors, one as master and four as slave. All of them have 2GB of memory and they work fine, however, the OS is Linux and not windows. Windows cannot handle such large simulations. Fluent can but with Unix based OSs.
Vinod Dhiman
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 03:44
Is the fluent mesh generate in windows can be used in linux? panda60 OpenFOAM 7 October 19, 2009 12:51
Any Luck with 64-bit FLUENT on 64-bit Windows? Dylan FLUENT 4 October 17, 2007 12:14
COMPATIBILITY OF FLUENT WITH WINDOWS XP varghese FLUENT 0 February 12, 2002 07:09
Can FLUENT run under Linux with 2 Gb of RAM? Paul Gregory FLUENT 0 February 13, 2001 21:10
