my fault about UDF
Old   February 5, 2006, 02:05
Default my fault about UDF
Seyed Farid Hosseinizadeh
Hi everyone, Could you please send me your points about my UDF file. I recieve an error about variable "n". #include "udf.h" "Error: adjust1.c: line 18: non-integer subscript expression: unsigned char." Regards,
DEFINE_ADJUST(unsteady_temperature, d) {
float x1,y1; face_t f; cell_t c; Thread *t; int i,n; Node *v;
i=0; begin_c_loop(c,t)
c_node_loop(c, t, n)
v = C_NODE(c,t,n);
x1 = NODE_X(v)
printf("faridd: %g\n",x1);
} end_c_loop(c,t) }
Old   February 5, 2006, 04:55
Default Re: my fault about UDF
RoM
No #include udf.h" at the top
Use "real" instead of "float" or "double"
Missing semicolon at end of line x1=NODE_X(v)
Some udfs will not run in interpreted mode. If the interpreter still fails try to compile.
RoM
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 08:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
