February 3, 2006, 15:57 |
Adaptation failing in // Fluent case?
Hi all,
I am trying to adapt by Y+ to get my turbulence model in the correct range. The case is large, and is run on 6 computers in parallel. When I do the Y+ Adaptation, it marks the cells, but does not display them, and when I click adapt, it does not adapt anything. If I load the case onto a single computer, it displays the marked cells for adaptation, and goes ahead and adapts it - but fails because I am out of memory. Why can I not adapt Y+ in the parallel case? Thanks Riaan |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 13:07 |
fluent case n data files not exporting to tecplot | krishna | FLUENT | 2 | February 18, 2007 00:24 |
Case in Fluent Tutorial 1 | Lam | FLUENT | 0 | August 24, 2004 12:25 |
Fluent adaptation procedure | wassim | FLUENT | 0 | June 11, 2004 15:12 |
Fluent case file into Gambit | Eric R. | FLUENT | 7 | July 17, 2002 15:11 |
