pls help with udf file
Old   February 3, 2006, 12:50
Default pls help with udf file
Arif
when I was doing dynamic mesh tutorial of flent i was trying to compile valve c file but i couldn't be able to create the file in library.please help me with ur support. Thanks Arif
error message: "C:/Documents and Settings/arifuzs2/My Documents/New Folder/dynamic_mesh"
Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
Error: no motion udf or profile was specified. Error Object: #f
Old   February 7, 2006, 12:10
Default Re: pls help with udf file
Rudi
Most likely your udf is not being compiled. If you are running on Windows & using Visual Studio.NET try starting Fluent from Microsoft Visual Studio.NET Command Prompt. (MSVS .NET>MSVS Tools>MSVS.NET Command Prompt & type fluent in the command window).
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 05:26
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 18:33
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
