Faces link
Old   February 3, 2006, 09:38
Default Faces link
Pamela
Hi, I'm trying to link two faces for mesh, one over the other, that have 36 holes (the two faces are the upper and bottom sides of the distributor of a hydraulic turbine). I selected the two faces and one edge of each loop but when I apply I receive this message:
error "two faces have inconsistent lower topology".
But there aren't problems in the geometry. Have someone an idea to solve the error? Thanks in advance to everyone
Old   February 6, 2006, 09:54
Default Re: Faces link
Emanuele
Problably you have one loop on a face with a different number of edges of the correspondent loop on the other face. Hope this helps
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
