Inlet : Turbulence Specification Method
Old   February 2, 2006, 11:40
Default Inlet : Turbulence Specification Method
PK
I have a problem by setting my inlet's Turbulence specifications.
I want to simulate the flow around a Cylinder which is moving in a water tank at a velocity of Vcyl . It is assumed that the water in front of the cylinder has velocity=0(motionless).
Question : how to set the inlet's Turbulence specifications ?: I use Inlet velocity boundary (Is it the best in this case?)with : 1- velocity Boundary = Vcyl. 2-Turbulence specifications = keps 3-Turb Kinetic Energy = Which value to used ? 4-Turb Dissipation RAte = Which value to used ?
Thanks for your help PK
Backflo direction specification method vijay FLUENT 6 August 27, 2015 13:29
turbulence intensity at inlet raju Main CFD Forum 1 November 16, 2006 01:13
Turbulence Specification Oliver FLUENT 5 March 23, 2001 13:24
Multigrid Method in Turbulence Modelling Bipin Lokhande Main CFD Forum 1 November 11, 1998 20:20
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 05:24
