parallel processing problem with multiproc machine
Old   January 28, 2006, 16:51
Default parallel processing problem with multiproc machine
hajra_rabaeto!!!!!!!
Hi everybody! I have a case which I solve with coupled implicit solver, about 500,000 cells. I tried to solve on 1 processor first to see how fast it does 1 iteration, and then tried with 8 processors. Surprisingly it was not faster. So my question is how does one efficiently distribute the job between 8 processors?
Thanks a lot.
Old   January 28, 2006, 18:15
Default Re: parallel processing problem with multiproc mac
Charles
First thing to look at is the speed and latency of the interconnect, if it is a distributed system. Also, splitting 500 000 cells 8 ways is a bit too much. Try it with 2, 4 and 6 to see if that helps.
Old   January 28, 2006, 20:11
Razvan
Coupled implicit solver requires heavy communication between CPU's (segregated and coupled explicit solvers don't). So it is efficient only when used on shared memory machines, where all processors have acess to all the memory in the same time. When used in a distributed memory environnement (supercomputer or cluster), its peformance degrades very quickly especially on small grids.In my experience, you will have to partition the grid with at least 200.000 elements per partition, so on this case you will have to use 2, max. 3 CPU's !!
Or you could switch to explicit solver, if you really have to solve using coupled solver.
Razvan
Parallel processing problem with Fluent Harish FLUENT 3 February 8, 2011 10:49
Problems with MFIX code and Parallel Processing. Fernando Pio Main CFD Forum 4 August 29, 2006 15:33
About parallel processing in Linux tuks CFX 10 August 8, 2005 09:22
parallel mode - small problem? co2 FLUENT 2 June 2, 2004 00:47
PC vs. Workstation Tim Franke Main CFD Forum 5 September 29, 1999 16:01
