Help please: submitting fluent jobs to sgi cluster
Old   January 27, 2006, 06:38
Default Help please: submitting fluent jobs to sgi cluster
James Willie
Hi All,
Is anyone running fluent jobs on an SGE cluter? I am having problems with the journalfile that has the fluent commands. I keep getting the following message: error occur during reading the journalfile. Some commands might not have been completed.
Any suggestions or a copy of your script file that has been used for this cause will be appreciated. I am able to run Fluent interactively and so the case setup is ok. Running it in batch mode on an SGE cluster is causing the problem.
Thanks in advance for the help.
Jimmy
script file for running fluent on linux cluster Worth FLUENT 2 February 9, 2012 12:31
poor performance at massive parallel run using SGI cluster matthias OpenFOAM Running, Solving & CFD 8 October 21, 2011 09:24
Jobs in cfd - fluent or cfx? jobman Main CFD Forum 6 July 5, 2006 16:02
HELP: submitting FLUENT JOBS ON SGE CLUSTER James Willie FLUENT 0 January 27, 2006 06:42
How to terminate fluent batch jobs? Martin S. Rasmussen FLUENT 5 August 11, 2004 13:01
