Gambit: mesh size to small???
Old   January 27, 2006, 03:53
Default Gambit: mesh size to small???
Ralf Schmidt
I am trying to mesh a komplex geometry and get following error for a lot of edges:
"WARN: Exact projection failed for node on edge xx near vertex xx. mesh size may need to be enlarged for this virtual edge if mesh is not acceptable"
I don't have any virtual edges in the geometry. And when I use coarser mesh, the meshing failed as well (mesh size to large in the area of small gaps). I mesh 3D with ted/Hybrid
Anny suggestions??? How can I display, which edges or faces are not succsessfully meshed?
Ralf
Old   January 28, 2006, 02:26
Default Re: Gambit: mesh size to small???
Omar Qazi
I think I have faced this problem once and this may be solved by adjusting the tolerence to a lower limit in the program defaults. It is set to 1e-3 and you can reduce to 1e-5 or 1e-6 to eliminate the problem you are facing. Then try to re-mesh with a finer grid.
When the velocity is small, the dynamic mesh doesn't move li2150 FLUENT 0 January 3, 2011 11:27
ICEM Tetra mesh, Size reduction and Skewness problem Catthan ANSYS Meshing & Geometry 6 December 5, 2010 20:39
unstructure mesh size control near to wall using gambit lalit kumar FLUENT 4 July 6, 2010 16:13
Mesh size for particulate flow simulations Shahri Main CFD Forum 0 March 24, 2009 18:40
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
