Turbulence models integrable upto the wall
Old   January 26, 2006, 13:15
Default Turbulence models integrable upto the wall
vishwas
Are the k-w, Spalart-allmaras, and LES models integrable upto the wall in fluent? I know that the k-epsilon model is not integrable upto the wall in fluent. Where can I get the guidelines for meshing the model if I want to use a model which is integrable upto the wall?
Thank you
Old   January 31, 2006, 17:59
Default Re: Turbulence models integrable upto the wall
mehdi khademi
If your problem is modelling a low reynolds-number turbulent flow, you must use "Enhanced wall treatment" option in k-e model and "transitional" option in k-w model. Irrespective of either of the strategis, you must put your first grid point near the wall in laminar sublayer, i.e Y+<1.
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Turbulence Models and external flow. Alan FLUENT 3 November 22, 2005 05:46
Wall turbulence, viscosity, boundary layer Patrick Godon Main CFD Forum 1 November 5, 2003 16:39
abt near wall turbulence wall functions amv Main CFD Forum 0 May 12, 2003 04:38
X-Y plot of Yplus in Fluent 5.3 Luo FLUENT 24 April 11, 2000 07:07
