Problem with Dissipation rate storage in UDMI
Old   January 26, 2006, 06:19
Default Problem with Dissipation rate storage in UDMI
Sam
Hello, I will try to explain the problem that I have when I store the value of Turbulent Dissipation Rate (Epsilon) into an UDMI. I need to calculate a drag coefficient with epsilon but i wanted to check if the variable C_D(c,t) is well considered in my function. So Compiling is ok, but when I watch the contours of "Epsilon" and the "UDMI" corresponding to epsilon, the values are different if "node values" is checked, the non-"node values" are however the same (which is good).
But I want to know why in this case the "node values" are different. This only happens with "Epsilon". Storing "k", for instance, in an UDMI gives the same value as the "k" calculating from Fluent.
Thanks Regards, Sam
question for specific dissipation rate kippo Main CFD Forum 8 April 2, 2021 16:42
Turbulence dissipation rate source roman10 STAR-CCM+ 0 May 9, 2011 13:29
Roughness length, interpolation, unphysical dissipation rate on the ground apaleftos STAR-CD 0 February 14, 2011 05:37
Dissipation rate access K. Kevala FLUENT 0 July 14, 2004 12:11
Turbulence dissipation Rate Rahul FLUENT 0 January 29, 2004 11:37
