Startup Problem in Gambit 2.2 with WindowXP
Old   January 25, 2006, 08:54
Default Startup Problem in Gambit 2.2 with WindowXP
Win Win Maw
Dear ALL, When I run on my PC using WindowXP,I meet following problem shwing in "Gambit Startup".
[ Gambit failed in locating Exceed installation on your system. Please try to start Exceed manually before you run Gambit. Cannot open connect stream. TRANS(SocketINETGetAddr): tnamebysocket() failed TRANS(SocketINETConnect): TRANS(SocketINETGetAddr) () failed TRANS(Open): transport open failed for tcp/SSCR-E4:0 Unable to open display ]
Please let me know how I should do.
Old   January 25, 2006, 09:03
Default Re: Startup Problem in Gambit 2.2 with WindowXP
HVN
You need to have exceed already installed on your pc in order to run Gambit.
Old   January 25, 2006, 10:59
Win Win Maw
Thank you HVN
Can I get free download Exceed?Can Gambit run during disconnection of server?
Old   January 25, 2006, 12:09
HVN
You could download exceed on the fluent user website or ask a Fluent representative to send you the exceed cdrom.
You need to be connect to the license server to run Gambit
Gambit Startup Window Jay Shim FLUENT 2 February 12, 2015 15:05
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
gambit startup problem coolprudhvi ANSYS Meshing & Geometry 0 July 1, 2011 03:34
Gambit startup options PAD FLUENT 0 July 21, 2006 06:38
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 10:22
