A question about Fluid Mechanics and FLUENT
Old   January 24, 2006, 03:05
Default A question about Fluid Mechanics and FLUENT
cc
Dear users
In the Fluid Mechanics literature, for example written by Frank M. White in my case, we have a diagram of "flow losses in a gradual conical expansion region". It is the pressure loss curve for the flow in pipes situation. The pipe has a conical expansion and the loss K is clearly obtained from here.
Now my problem is I can't verify any result of K although i have accomplished to do the analysis properly in Fluent. I have made many tries with several conical angles and several inlet velocity values. Just for an example i find K=0,09 although it is K=0,5-0,6 from the diagram in the textbooks.
Do you have any experience on this or do you have any sugestions?
I can send you my model.
Old   January 24, 2006, 03:58
Default Re: A question about Fluid Mechanics and FLUENT
lcw
I also have the same experience in the simulation of straight circular pipe. The result by K-e model is close to the that of Frank M. White But the The result by RSM model have a big difference though y+~1.
Old   January 24, 2006, 04:07
cc
I have used the k-e model. Do you think RSM improves the results? Big difference ı have though.
Old   January 24, 2006, 05:50
lcw
No, I feel RSM model gives big difference between the simulation and empirical formula, k-e model gives a good result. I don't know the reason.
Old   January 24, 2006, 07:36
cc
What was the % error in your study comparing to the literature?
Old   January 24, 2006, 12:07
LCW
RSM model gives about half of the empirical formula's result.
Look for job, a CFD project using fluent! roozy FLUENT 2 April 20, 2010 02:28
which one? FLUENT, Star-CD or CFX? M. Amin CFX 2 February 14, 2004 01:21
which one? FLUENT, Star-CD or CFX? M. Amin FLUENT 6 February 9, 2004 04:45
which one? FLUENT, Star-CD or CFX M. Amin Main CFD Forum 1 February 8, 2004 21:52
I wanna have FLUENT aditya FLUENT 2 January 29, 2004 20:43
