Surface Integrals
Old   January 23, 2006, 17:47
Default Surface Integrals
Philip Oliver
Running a 3d simulation of flow through a blockage, I was trying to calculate, in surface integrals, the mass flow rates through planes at different locations downstream. Expecting to get constant values in the planes I was evaluating, the values seem to vary a fair bit. The flow is fairly complicated but the residuals are quite low, most are below 1e-6 although continuity is nearing 1e-5. In this compressible simulation, the planes that were most obviously incorrect had flow in both directions, recirculation zones. Is this because of the way Fluent evaluates a dot product of the area vector and the velocity vector? Any ideas? Thanks a lot.
Old   January 24, 2006, 19:08
Default Re: Surface Integrals
Thomas
How have u defined the bc? with compressible flows u should you a mass flow inlet and not a velocity inlet.
Old   January 25, 2006, 13:56
Philip Oliver
Hi, thanks for your response.
I have defined the inlet and outlet as pressure BC's. In gambit I defined a couple of interior surfaces that give the right mass flow rate but when I create my own planes in Fluent it gives values that are considerable larger. I'm not sure why that is.
Thanks again, -philip
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
Mismatch between Fluent Surface Integrals Report and Surface Line/Rake Tool emlejeen FLUENT 0 March 31, 2010 12:21
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
