January 22, 2006, 00:50 |
Heat transfer from solid to liquid
Having trouble getting this to work. How do I set the interface. I have a coupled interface between a solid and liquid zone but no heat flux results! Any ideas? Thanks you
January 24, 2006, 19:19 |
Re: Heat transfer from solid to liquid
Have u set the bc for the wall?
thomas |
January 30, 2006, 05:10 |
I too have same problem I have set up boundary as wall ....but i thik it is not right ....can any one guide on this issue...my problem is reverse ....in my problem DO model is used and i got result for air and I am getting a flow of air alos but though wall is near heated air ir is not getting heated.......
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 06:43 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 23:22 |
No Heat Transfer between two solid domains | Mike ZH | CFX | 7 | July 26, 2008 17:50 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 07:47 |
