Parse error
Old   January 21, 2006, 08:10
Default Parse error
Fernando
Hi. I'm trying to interpret a UDF in Fluent 6.2, but I get an error message:
"cpp -IC:\Fluent.Inc\fluent6.2.16/src -IC:\Fluent.Inc\fluent6.2.16/cortex/src -IC:\Fluent.Inc\fluent6.2.16/client/src -IC:\Fluent.Inc\fluent6.2.16/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" C:\Fluent.Inc\Ejemplos Fluent\pexit.c Error: C:\Fluent.Inc\Ejemplos Fluent\pexit.c: line 1: parse error."
If i use the Contributed CPP option, the error message is the same:
"C:\Fluent.Inc tbin tx86\cpp.exe -IC:\Fluent.Inc\fluent6.2.16/src -IC:\Fluent.Inc\fluent6.2.16/cortex/src -IC:\Fluent.Inc\fluent6.2.16/client/src -IC:\Fluent.Inc\fluent6.2.16/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" C:\Fluent.Inc\Ejemplos Fluent\pexit.c Error: C:\Fluent.Inc\Ejemplos Fluent\pexit.c: line 1: parse error."
The UDF I'm trying to interpret is the following (it comes from the Fluent tutorials):
#include "udf.h"
DEFINE_PROFILE(unsteady_pressure, thread, position) {
float t, pressure;
face_t f;
t = RP_Get_Real("flow-time");
pressure = (0.12*sin(2200*t)+0.737)*101325.0;
begin_f_loop(f, thread) {
F_PROFILE(f, thread, position) = pressure;
end_f_loop(f, thread) }
I've been reading all the posts about this same problem, but I haven't found a solution. The UDF is in the same folder as the case files, but I always get the same error. Can anybody help me?
Old   January 21, 2006, 09:57
Default Re: Parse error
lcw
Advise you to delete space in the name of current folder. Lucky!
LCW
Old   January 21, 2006, 13:55
Fernando
Uf, thanks very much, LCW, I was becoming crazy!
Fer
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
nonNewtonian viscosity model mhassani OpenFOAM Programming & Development 5 January 7, 2013 10:27
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 21:23
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 21:11
user defined function cfduser CFX 0 April 29, 2006 11:58
