Dilute fluidized bed dryer using DPM
Old   January 21, 2006, 06:59
Default Dilute fluidized bed dryer using DPM
masood
Dear friends; i wanna use DPM to simulated a fluidized bed dryer. Geometry: a vertical cylinder with 2 input and 2 out put. fluidizing gas enters from botom of the cylinder and exits from top of the cylinder. wet-solid enters from top side of cylinder and exits from botom side of cylinder. which particle BC's must i use?reflect?escape?wall jet?trap?...? regards masood
Old   February 6, 2006, 03:57
Default Re: Dilute fluidized bed dryer using DPM
saeed al-hoqbani
To dry Poly Vinyl Chlorid(PVC) as a wet cake. This product is 20 -30% moisture of water we need to dry it to 0.2-0.1%. we need to dry 600kg within 1-2hr.it will be better to have mixture inside the dryer to mix the product in the early stage of drying otherwise the product will be compacted at the bottom of the dryer
if you have that dryer please, send me more information
expansion of bed in fluidized bed achy7pch FLUENT 7 August 10, 2024 04:33
DPM Particle types, Spray Dryer Mohsin FLUENT 1 August 2, 2011 22:26
Fluidized bed modeling Kartus CFX 9 June 30, 2011 05:41
Fluidized bed simulation VS particle tracking windhair CFX 2 June 28, 2011 22:10
Fluidized bed simulation Siaw Khur CFX 3 July 28, 2010 15:42
