divergence problems
Old   January 20, 2006, 11:23
Default divergence problems
Kaatje
Hello, I am simulating a tube with 2 curves through which water-vapor is sent. Fluent has problems to solve this when I set a heat flux profile (udf) as a boundary condition. I am using ideal gas law for the density of water-vapor. With under-relaxation factor 1 for energy the solution shows divergence and gives error: temperature limited, turbulent viscosity limited. With lower under-relaxation factor the simulation convergence goes too slow. I already tried to solve flow and energy separately. Does someone know what to do about it? Thank you.
Old   January 20, 2006, 12:41
Default Re: divergence problems
Laika
Hello Kaatje,
can you please give some more info. A double bended tube can have strange physics, so maybe the physics cause problems.
Is your model converging without the UDF? What flow inlet velocity do you have? Is it mass flow in - pressure out?
cheers, Laika, still orbiting
Old   January 22, 2006, 09:23
Kaatje
There are some simulations without the udf but with constant heat flux or constant temperature as boundary condition that converge. But with increasing heat flux they show divergence. I also managed to do one simulation (operating pressure=4.025 bar) with the udf that converges but when I try to do the same simulation with a different operating pressure (4.035 bar) the simulation isn't converging anymore. The inlet velocity with the ideal gas law is about 30 m/s (mass flow inlet=0.29 kg/s). I use mass flow in and pressure out. Kaatje
Old   January 23, 2006, 14:50
Laika
Hi Kaatje,
how does your mesh look like?
Does it diverge rigth from the start, or after a while?
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
Problems modeling vertical axid water turbine- divergence in AMG solvers gambiss FLUENT 1 March 13, 2011 14:05
Divergence problems with interface in 2D transonic external flow drrbradford FLUENT 1 June 23, 2010 12:09
problems simulation ideal gas, divergence in AMG S Ralf Schmidt FLUENT 11 October 1, 2005 14:21
LES NITA giving divergence problems anindya FLUENT 0 June 20, 2005 08:23
