Turbulant Viscosity ratio is limited to 10e5.
Old   January 19, 2006, 07:07
Default Turbulant Viscosity ratio is limited to 10e5.
MKP
Dear user,
i am solving steady high speed compressible flow.
1] Why does fluent show turbulent viscosity ratio is limited to 10e5.?
2] Does it affect the result or convergence..?
3] How to set the turbulent viscosity ratio limit for a problem?
Thanx n Advance.
M K P
Old   January 19, 2006, 14:40
Default Re: Turbulant Viscosity ratio is limited to 10e5.
J. Kim
Your computation will give wrong answer. Try the followings (There might be other ways to avoid this weird numbers).
1. Use different initial conditions when you start initialization.
2. Reduce relaxation factors (for ex. 0.01. Is this extremely small? Anyway please try.)
3. If it does not work, try unsteady simulation at first. And then turn on steady simulation.
4. Mesh adaptation.
5. Remesh. This is the best way!
"turbulent viscosity limited to viscosity ratio" olivier FLUENT 11 October 10, 2015 06:49
Turbulent viscosity Limited to viscosity ratio Adrian FLUENT 12 September 21, 2011 05:22
Turbulent viscosity limited to viscosity ratio... Cyril FLUENT 8 February 7, 2006 21:34
turbulent viscosity limited to viscosity ratio mukkarum FLUENT 3 May 11, 2004 05:05
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 07:13
