problems orientating profile
Old   January 19, 2006, 03:48
Default problems orientating profile
Ralf Schmidt
I want to read in the boundary profile xxx into my simulation as a velocity inlet. The profile xxx has the same orientation and the same size as the surface in my geometry that is defined as velocity inlet.
But when I start iterating, it turned out, that the profile at the velocity inlet is 90° turned to the original profile xxx.
Now I used define->profiles->orient to orient my profile. After that, the only message is
"warning: no x,y or z points specified in profile xxx"
And I can not iterate...
What is the problem?
Ralf
P.S. has someone the online help for the version 6.2.16 ?? I can only access the 6.0 ant the 6.1 documentation
Old   March 30, 2014, 11:00
Astio Lamar
asal is on a distinguished road
Dear Ralf Schmidt
Do you find any solution of the issue. I have the exact same problem as you had!
asal is offline   Reply With Quote
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 13:13
Some problems with Star CD Micha Siemens 0 August 6, 2003 14:55
Making boundary profile on a surface in xz- plane varghese FLUENT 6 May 3, 2002 09:38
how to obtain a profile ... olivier FLUENT 2 December 13, 2001 07:21
Boundary conditions profile Christophe Doublet FLUENT 1 June 14, 2001 01:27
