Help Me: dispersed turbulence model&kinetic theory
Old   January 18, 2006, 00:52
Default Help Me: dispersed turbulence model&kinetic theory
colin
I am working on gas-solids flow(relatively dilute, solid mass loading less than 12) in pipes simulation using fluent6.2.16. I have some troubles on the granular multiphase modle.
when solving solid phase granular temp. equation, I use PDE in Fluent6.2. And i use dispersed turbulence model. when I using the dispersed turbulence model, it says that the collisions between particles are neglected. it seems conflict with the kinetic theory. But, when i change the particle-particle collision restitution coefficient, the result(pressure,volume fraction of solid phase) is changed too.
Kinetic Viscosity :Gidaspow et al. drag: Gidaspow
How does the dispersed turbulence model affect the granular temperature equation? And will the turbulence in the Dispersed Phase in my model be solved or neglected? can i use the dispersed turbulence model?
I would appreciate if you can share your experience with me and give me some advice on it.
Old   January 20, 2006, 20:55
Default Re: Help Me: dispersed turbulence model&kinetic th
colin
thank you in advance!
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 15:18
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
kinetic energy in k-e dispersed turbulence model? tim FLUENT 0 March 29, 2007 15:24
