Gambit via X11
Old   January 18, 2006, 00:16
Default Gambit via X11
Josh Kjenner
Howdy;
My lab runs Fluent/Gambit on Linux boxes, and because of it's cave-like atmosphere I would prefer to remotely log in from home on my mac using X11. However, I'm having some problems.
Here's the specifics: I'm running Mac OS X 10.4, and I'm using X11 1.1 to do the remote login. I've enabled X11 forwarding, and use the following command:
ssh -X -l jkjenner linuxbox.thayer.dartmouth.edu
From here, I can run Fluent with no trouble. However, when I fire up Gambit with this command:
gambit -id modelname
I get this message:
This product has the following patch(es) applied: patch_2230_1
You can find more information about the patch(es) in the respective text file(s) located at: /usr/local/fluent/Fluent.Inc/gambit2.2.30.
LANG en_US.UTF-8 changed temporarily to C for gambit use. Starting /usr/local/fluent/Fluent.Inc/gambit2.2.30/lnx86/gambit -id basegeom... OPENGL_DEVICE_DRIVER not supported
Defaulting to X_DEVICE_DRIVER with standard visual. Received X Error <9: BadDrawable (invalid Pixmap or Window parameter)>. XErrorEvent:
display = localhost:10.0
type = 0
resourceid = 87
serial = 240
error_code = 9
request_code = 73
minor_code = 0
Received exception: SIGSEGV (segmentation violation)
Please send the GAMBIT.24790/jou and GAMBIT.24790/trn files to your local Fluent office or distributor. Also send a message including any relevant errors or warnings you see above in this window. You may wish to delete the temporary directory GAMBIT.24790 after sending the above files. ERROR: Please retain a copy of the GAMBIT.24790/jou, GAMBIT.24790/trn, and GAMBIT.24790/*.dbs files, any imported geometry and any relevant errors or warnings you see above in this window and contact support at your local Fluent office or distributor. Abort
Any ideas? Does anyone know if it's even possible to run Gambit via X11? I've seen some old forum posts from people claiming they've done it, but haven't been able to get in touch with them.
Thanks,
Josh
Old   January 24, 2006, 20:21
Default Re: Gambit via X11
Josh Kjenner (again)
If anyone is using a mac and trying to run Gambit, you might be interested in this:
To get it going, I ssh'd in to the Linux box using the -Y switch instead of the -X switch, which apparently enables "trusted" X11 forwarding instead of just regular X11 forwarding. I then started up gambit with the following command
gambit -dev X11 &
And, lo and behold, it worked. Hooray for me.
[GAMBIT] Canīt start GAMBIT zalho ANSYS Meshing & Geometry 18 April 8, 2019 02:05
How to open a saved Gambit File? barkan FLUENT 5 September 1, 2012 06:53
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 07:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 13:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 09:33
