January 13, 2006, 23:08 |
A question about flow between 2 plates
Hi, I have a very simple question. I'm trying to verify Poiseuille flow (between 2 flat plates, laminar, with air) but when flow meets the plates at the entrance point on the plate, the velocity won't be zero at that point. The velocity on the plate at entrance will be averaged one (between initail velocity and zero) and caused the velocity profile at entrance region. I'm just a beginner of FLUENT and I really run out of ideas. Appreciate any help!! Thanks
January 18, 2006, 04:46 |
Re: A question about flow between 2 plates
A constant velocity inlet doesn't exist in reallity..
To avoid this problem you can either: 1) use periodic BC at the inlet and outlet. This perfect if you want to study a fully developped flow...you need also to impose a pressure gradient between the inlet and the outlet. 2)you can write an UDF with a defined velocity profile(parabolique or whatever)...with a null velocity at the wall. This good if you want to study the developpement of your flow along the duct or the channel. How long does it take to get a fully developped flow....etc. |
January 23, 2006, 06:07 |
how we can generate mesh in gambit between two inclined parallel plates?
Flow between parrall plates entry length formual? | S. S. Mudathir | Main CFD Forum | 4 | June 24, 2015 08:24 |
a question about mass flow in multi-component flow | frank | CFX | 0 | May 12, 2008 07:38 |
Question on Unsteady Flow | Ben | CFX | 5 | January 17, 2008 17:04 |
Question about Couette Flow | Tiger | Main CFD Forum | 1 | March 23, 2006 23:16 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
