HOW KEEP ON INJECTING DPM DROPLETS
Old   January 13, 2006, 00:36
Default HOW KEEP ON INJECTING DPM DROPLETS
Prince Samson
I tried injecting dpm particles in a rectagular tank (2d).....the injecting process is done only once....how to keep on injecting the particles ......
Old   January 13, 2006, 15:35
Default Re: HOW KEEP ON INJECTING DPM DROPLETS
pradeep
If you enable "unsteady particle tracking" option in Define->Model->DPM. then in injecitons you can specify the start and end time and also the mass flow rate.
Hope that helps
Falling droplets (DPM), rel. humidity > 100% ???? Wikie FLUENT 0 October 25, 2010 05:52
influence of porous zone in particel resistance time using Euler-Lagrange and DPM ?! Wikie FLUENT 0 April 23, 2010 07:07
Interesting Injection result of DPM? Rachel FLUENT 2 July 8, 2008 19:00
DPM - droplets John FLUENT 4 August 21, 2005 01:12
DPM & melting of metal droplets Spyros FLUENT 0 June 6, 2005 16:20
