January 11, 2006, 08:59 |
3d Aeroplane meshing
Hi, we have been trying to mesh half a 3d aeroplane in Gambit for weeks now and have searched the forum and still can't get our problem solved; Please Help.
We have done tutorial 12 and it worked perfectly. We then applied this tutorial information to our aircraft and it worked, but when we imported the mesh into Fluent, some nodes are not used. We do get results but we are getting very high lateral forces (i.e. through the symmetry plane). We would expect this to be 0. We are now trying to subtract the half aircraft volume from the brick volume to give one volume as in tutorial 6. When we mesh it now we get an error message saying: 'tetrahedral mesh has failed for volume v_volme.4. This is usually caused by problems in the face meshes. Check for skewness of the face meshes. Make sure the face mesh sizes are not too large in areas of small gaps'. What would you suggest we do? Please help, we are in real trouble. I thank you in advance for any help! Cheers, George |
January 11, 2006, 09:22 |
Re: 3d Aeroplane meshing
Do you clean your geometry before meshing?
January 11, 2006, 12:00 |
Hi HVN,
Yes we have done clean ups. I guess there might me a problem with there being virtual volumes, i.e. non-real. ?? Thanks |
January 11, 2006, 12:12 |
I have sometimes this pb when I have very small surface compared to the global geometry
January 11, 2006, 12:36 |
ok thanks for that!
Cheers George |
January 20, 2006, 07:05 |
Hi, While modelling flow over aeroplane how do you decide on the size of external domain. Is there any atandard practice to decide on domain size ?
Thanks Venkatesh.V |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 06:22 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 12:03 |
Meshing locks workbench window. | andy2o | CFX | 0 | February 1, 2008 06:01 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 12:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 12:08 |
