Face ID out of range
Old   January 9, 2006, 06:23
Default Face ID out of range
Wenbin
I am having a problem with trying to reload a case/data file for visualiation. The problem is a typical flow problem over 3d wing. The solve phase went ok, I am getting an error message when trying to read the case file back:
Face ID 0 out of declared range (0<=id<=9384598). Reading Faces: failed while reading section 2013. Clearing partially read grid
Error: Read aborted due to critical error. Error Object: #f
Has anybody come across this issue?
Thanks Wenbin
Old   January 16, 2006, 10:33
Default Re: Face ID out of range
Jason
If you have your .msh file still, then you can rebuild your case and read in the final data. This only works if the case has the same number of cells as the data, so if you have to rebuild the mesh, this won't work unless you can build exactly the same mesh.
Only time I've had that was because we had a power outage when I was writing the case file. The file became corrupted and I wasn't able to read it again. Luckily I didn't lose too much because I was using the autosave feature during the solution.
There may be another way to salvage the case file, but I haven't found it. Of course, I've only had this problem once, so I didn't look too hard.
Hope this helps, and good luck, Jason
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
