Multiple Mesh Import Without Fusing
Old   January 4, 2006, 13:59
Default Multiple Mesh Import Without Fusing
Bottenheim
Hello
It seemed a little unclear to me, so I figured I'd ask here:
Is it possible to run multiple meshes using interface boundary conditions only (ie: coupling) rather than using the fuse command to fuse together adjacent boundaries between each mesh.
I tried to fuse bordering boundaries yesterday and managed to lock up a pretty powerful linux cluster, so if I could get away without fusing, this would be preferable at this time.
thanks!
Old   January 4, 2006, 17:51
Default Re: Multiple Mesh Import Without Fusing
Emanuele
Yes you can. You have two options for doing that: 1)Read both mesh in Tgrid and Tgrid automatically creates one mesh file. Then you save the mesh file and you can read the file in Fluent and create the boundary interface 2)Use tmerge utility directly in Fluent and then create the boundary interface in Fluent Hope this helps you bye bye
Old   January 5, 2006, 04:39
Bottenheim
Thanks, I will try this. Cheers.
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
Unable to import mesh on the CFX-Pre jarrai CFX 1 December 20, 2010 08:05
mesh missing after import in fluent morteza08 FLUENT 0 July 23, 2010 03:22
