Mixture fraction in Partially premixed combustion
Old   December 29, 2005, 16:59
Default Mixture fraction in Partially premixed combustion
Viktor
I am learning partially premixed H2/O2 combustion case with non-moving stratified mixture (prePDF 99%O2+1%H2 and 99%H2+1%O2 fuel and oxydiser compositions). However, I don't know how fluent prescribes concentrations - if I use c=0 and f=1 to initiate solution and it gives 0.3% H2 + 0.3 %O2 (not 99% H2 +1% O2) molar concentration withing my volume. Why it doesn't give me at f=1 compostion of the 100% fuel stream ?
Thank you very much,
Viktor
Old   December 30, 2005, 00:30
Default Re: Mixture fraction in Partially premixed combust
auth
The problem is solved. I had too many points between f=1 and f=0 (fuel steam and oxydizer stream). My small gird was made just as a sample case and Fluent was given totaly bogus numbers. I set now number of grid points in the flamelet to 9 and it works.
Viktor
Mixture fraction with PPDF combustion Erik Siemens 1 September 5, 2011 22:47
Mixture fraction with PPDF combustion erikrijk STAR-CD 0 March 18, 2009 09:49
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
Mixture fraction for combustion problem Jonathan Lemay CFX 3 November 5, 2007 15:57
